Old 06-12-2010, 11:05 AM
Snakebit's Avatar
Snakebit Snakebit is offline
Club Cobra Member
Cobra Make, Engine: ERA 289 FIA #2100 Rio Red Wimbledon White Stripes 302 stroked to 331 Webers Richmond Road Race 5 speed
I had to replace the rear main in my 302. It had a 2 piece seal. You need to drop the pan, and remove the rear main cap. If its a later block with a 1 piece seal, You need to pull the trans, clutch, and flywheel to change the rear seal. Make sure you replace it with a FelPro Performance rear seal. The seal I replaced was the rubber one supplied with the gasket set, POS. The Felpro seal is dry as a bone. Not hard to do, just very time consuming.
Snakebit
