Old 06-14-2010, 07:35 AM
khansmith's Avatar
khansmith khansmith is offline
Cobra Make, Engine: Hurricane Motorsports, Southern Automotive 428 FE
Originally Posted by strictlypersonl View Post
There is a bleed port in the master cylinder that allows fluid to run "backward" whenever the master cylinder piston is fully retracted. If more calipers were locking up, I would have speculated that the port was blocked, but in this case it obviously isn't.
Khansmith's problem is likely a loose or misaligned caliper, malfunctioning emergency brake mechanism, or a sticking caliper piston.
I am thinking the issue is a sticking caliper piston.
Hurricane Motorsports: HM1046
Follow the build on my blog: http://khansmith.blogspot.com/
1974 Pantera resurrection blog:http://1974pantera.blogspot.com/
