Old 06-14-2010, 07:54 PM
dlampe's Avatar
dlampe dlampe is offline
I have finished the install of the sway bar system. It is super adjustable and easy to tune. The rear bar is probably going have about 3 inches of ground clearance. That is still great for the track and most roads but some of the roads around here are crowned in the middle. (I should have wiped the stuff off before I took the pictures!)
The hiem mounts next to the lower shock mount.
There are a few different ways to mount the hiem joint to the bar to adjust the bars rate.
You can see the bar housing lying just behind the radiator.
High Maintenance Racing Team
Run & Gun 2003 - 2013
