  #23 (permalink)
Old 06-16-2010, 08:26 PM
JustOne JustOne is offline
Cobra Make, Engine: Unique FIA, 425 Windsor
From an earlier post, it sounds like you discovered that it is a two piece seal? If so just drop the pan, you don't need to remove the trans.
As mentioned earlier, make sure you use the FelPro performance seal. You will have to get this from Summit or Jegs, most likely your local parts store will not have this.
Justin
