Old 06-18-2010, 10:24 AM
barabar barabar is offline
Default Engine temps
Just a short note. There are so many things that can cause abnormal temperatures. Most people think that small radiators, fans, high or low thermostats. Even though that maybe part of the problem the other causes, can be clearances espeically thrust bearing. The other problem can be the degree of valve overlap.If your header size is wrong and your not scavenger all your exhaust gases (providing your timing is correct) this can be a major issue.
