Old 06-18-2010, 08:43 PM
sideshow sideshow is offline
how smart was yr guy who stripped the harness
i think if u paid him u should be able to get him to fix it
another thing is where di u get air flow from as there are afew different ones
another thing is get screwdriver and use it like stethoscope on each injector
as some might be stuck closed due to enigne sitting for so long
but yr auto elect should know htis if he does this often heheheheeh
no spd and no o2s it should still run right
end of the day it should run ok with ignition and injectors and tps and coolant
and airflow/air temp so anyhting else should not effect it
did the wiring guy fit a diag plug as most early fords and hodlens are a pain to diagnose
very crude system
id be checking for air leak and is it blowing black smoke out the back
u might have a problem with mismatched parts
i always see this when they person tries to buy the cheapest motor on the shelf
then spends another grand getting the bits for it
the old ford motrs in usa change so often so maybe find someone in usa that can match up part numbers for u
my website
www.sideshowsperformancewiring.com.au
