Old 06-19-2010, 02:25 AM
65hilly's Avatar
65hilly 65hilly is offline
Originally Posted by 750hp View Post
Mike,
The physical size of the 5 speed Supra box doesn't appear to be a problem. Rod Hadfield at Castlemaine Rod Shop www.rodshop.com.au will definitely be able to supply a bolt-in bellhousing/adaptor for the LS1 - Supra.
My worry would be how far back the shifter is.... I think my elbow would hit the rear firewall behind the seats when going for 2nd or 4th gears! I wonder if you can relocate it?
Just wondering where you got that info? I rang the Castlemaine rod shop, they said they didnt have a bell houseing for an LS1 to Supra gearbox, and said they wouldnt as that gearbox was really only good for 250hp? I was looking at this adaption myself as im fittling the LS1 into a 1970 capri. I have the standard auto 4 speed box, but would prefer a manual. although i have got a trans controller, that will allow full manual shift, so i could fit a paddle shift on the steering wheel. i guess my main issue is the size of the box, and i will have to cut the tunnel to fit it in. any ideas?
