Old 06-19-2010, 08:16 PM
flipscobra flipscobra is offline
Cobra Make, Engine: Superformance aluminum427
Default Oiling Studs
The oil does not go thru the stud on a FE it goes around the stud in 2 places. If you look at your head you will see a counter sunk hole on each head, in that countersunk hole you will see a hole on the side of the counter sink, this where the oil goes up thru your stand an thru the tube an oils your rocker arms.
