Old 06-19-2010, 08:48 PM
FWB's Avatar
FWB FWB is offline
i'm used to seeing the factory studs with a reduced diameter bolt, the clearance holes in the ford stands are a tight fit so they are clearanced for the oil travel up the bolt( yes the outside)
i was wondering if the erson stands have a larger clearance hole for the bolts or studs in this case, making the undercut of the stud unnecessary.
