Old 06-20-2010, 05:02 AM
Default How long is the shift??
Elmariachi Jim how long does the shift take?? The other thing is could this be the weights for the advance in the distributor returning to base for a split second. Heavy advance weight will do this or the motor may backfire through the pipes. No power loss just noise and flames. You are at WOT and lift of the throttle pedal for a moment, motor gets high vacuum, carb is partially closed and you get a pop. It's a timing thing. Advance the timing 2-4 degrees than go and road test the car. see if it is doing the same thing. Rick L.
