Thread: Dead Cylinder
Old 06-22-2010, 04:22 PM
Gun Doc's Avatar
Gun Doc Gun Doc is offline
Cobra Make, Engine: BDR#499 351W with Webers
RS,
I have sorted out the linkage. I replaced what was there with a very simple system (see my gallery) that works well. I also straightened the shaft so that should take care of that problem. I am pretty sure the original problem (dead cylinder) was caused by the bent shaft. Like I said in an earlier post, I also found that my intake gaskets were leaking. I had the “old” Fel Pro 1262 without the steel reinforcements. I am changing them out now with 1262-S.
Prior to the cylinder dropping, the engine was running okay. It was still rich on the idle circuit, but seemed to run well after 2500RPM. It made plenty of power from idle on…I am just tired of changing plugs every couple of months. I KNOW it is not right, but can be with the proper jetting.
Gun Doc
