Old 06-22-2010, 06:54 PM
madmaxx madmaxx is offline
KC has as many choices is as out there. make sure to check his website or better yet call him. His assssss is on the line on every engine he sells, it aint some guy working for a company at an hourly rate. The engine which is direct competion for the ford 427 and Roush 427 is:
427 SBF Street/Performance Crate Engine - $11,795.00
Horsepower: 580 hp
Torque: 565 ft/lbs
Block: Fully Machined and Prepped Dart Sportsman Block
Crankshaft: Scat or Eagle 4340 Steel Crankshaft
Stroke: 4.000”
Connecting Rods: Scat or Eagle H-Beam 6.250"
Pistons: Mahle
Timing Chain: Ford Motorsport Double Roller
Camshaft: Comp Cams Custom Grind Hyd Roller
Lifters: Ford Motorsport Hyd Roller
Cylinder Heads: CNC AFR 205
Valves: SI One Piece Stainless 2.08/1.6
Rocker Arms: Scorpion 1.6 Roller
Intake: Edelbrock Victor Jr
Waterpump: Edelbrock Aluminum
Carburetor: Quick Fuel 780cfm
Valve Covers: Keith Craft Logo w/Breathers and PCV Valve
Wire Looms: Smoothie
Oil Pump: Melling High Volume
Oil Pan: Moroso or Canton
Balancer: Professional Products
Ignition: MSD Distributor w/Keith Craft Logo Moroso Plug Wires
Gaskets: Felpro
Fasteners: ARP
Compression: 10.5:1
Fuel: Premium Unleaded Only
Firing Order: 1-3-7-2-6-5-4-8
Timing: 35 Degrees @ Full Advance
Oil: 10w-30 or 40 Non-Synthetic for Break-In
Max RPM: 6250
Dyno: Complete Test and Tune on SF902 Dyno
Price: $11,795.
I have also driven some big blocks and they had nice torque on the low end, what was missing on the ones I drove was the blistering acceleration above 4500 rpm, the stroked 427's seem to explode above 4Krpms. The big blocks acceleration appears linear where the small block is exponetial.
Now go with a KC 482 with 600 plus hp I think you would have the best of both worlds if you did not kill yourself.
Might want to call Eric at Performance Engineering also, he builds some nice motors at competive prices.
I have learned at times when dealing with corporations the guy / gal on the other end does not have the same equity into the deal as the business owners themselves. I am led to beleive if you call with a problem you are not going to be talking to Henry Ford or Jack Roush, maybe, but I doubt it. You call KC or Eric at performance engineering you will be talking to them, the guys that can make a decision in an instant. No other approval required. Look what vendors post and supports on this forumn.
BDR = Cashburn
SPF's = Vintage Upgrades / Mustang Ranch / Keith Craft
Engines = Keith Craft
