Thread: Concreters
Old 06-22-2010, 09:04 PM
boxhead's Avatar
boxhead boxhead is offline
My shed is 16mx12m and 4.6m wall height.
Quote I have is for 100mm thick 130mm in hoist and mezzanine area (4mx12m) with second level of reo, plastic water barrier and scalps (blue metal) base at 50mm deep, footings at 450mmx450mm 300mm deep and a 150mm boxing around outer walls of slab.
25mpa with 20mm rock.
He advised that 25mpa when dried and set will be higher.
He did a slab a few weeks ago at 32MPA and 5 days later when tested it came in at 45MPA.
Cruising in 5th
