Old 06-23-2010, 06:37 AM
priobe's Avatar
priobe priobe is offline
Cobra Make, Engine: E-M Cobra Ford FE 427 w/ Webers 48 IDA
Default Coil over adjustment information needed
Hello all,
Ok here is the situation. I have coilovers all the way around on the car. When I started adjusting them I would make the adjustments in increments of 4 turns. When I started it was all the way adjusted to the bottom. I know adjusted the compression of the spring to almost an 1inch from the bottom thread. I thought I was pretty sure that by compressing the spring closed it would lower the ride height. I am noticing that the ride height is going up.
Does this make sense?
I could put my whole fist inbetween the tire and the body. Am I doing something wrong?
These are ALdan coilovers and I can not find a phone # for the company.
