Thread: Need appraiser
Old 06-23-2010, 06:45 PM
Fordzilla's Avatar
Fordzilla Fordzilla is offline
Cobra Make, Engine: 1969 Mustang Fastback Pro-Street, constantly changing ongoing project!
Mike, Although the guys mean well, they are obviously not antique gun guys. Yes, It is US Military. Yes it is a US arsenal 50-70 conversion. Lack of cartouche on the stock is common. The stock was replaced at time of conversion & barrel relining. Yes, it needs to be cleaned. Yes, you can clean the bore with a bore brush. Use a 50 caliber brush & remove all the lead & grime you can. After that I can tell you a trick used by the pros to clean the remainder. Easiest to describe over the phone. Yes, the active rust on all metal should be removed. Don't polish it, just clean off the rust, leaving the metal patina intact. Bronze wool should be used with a light oil. Automatic Tranny fluid works great.
Mick
(Of The Troops & For The Troops)
Life is not a journey to the grave with the intention of arriving safely in a pretty and well-preserved body; but rather a skid in broadside, thoroughly used up, totally worn out, and loudly proclaiming, "WOW, WHAT A RIDE!"
