Old 06-24-2010, 06:46 PM
Jerry Clayton's Avatar
Jerry Clayton Jerry Clayton is offline
Yes--
They will fail and slip if they have had to actually dampen harmonics over a period of time---could be a few seconds or several years--
Harmonics can come from several sources----there are several orders within the engine itself, and also is extended thru out the complete driveline---driveshafts on cobras are quite short and angles are severe--half shafts--wheel balance/wobble, etc
For an example of several years---Ford pickups have a terrible front end ball joint problem, which causes errattic tire wear---rotate those shaking tires to the rear and they create a harmonic vibration back up thru the drive shaft killing the harmonic dampener!!!!
