  #32 (permalink)
Old 06-26-2010, 09:35 AM
StanJ StanJ is offline
Originally Posted by vector1 View Post
The test for IFR's / idle air bleed combo is adjust idle for best mixture, then turn up the idle speed to about 1200 - 1400, under where the main circuit begins feeding fuel. Turn the idle screw out to see if the idle speed increases with the additional enrichment. If the engine rpm increases, you probably need more IFR. You can also turn the idle speed screw in to see if it is too rich. If turning the mixture screw in increases engine rpm then the IFR is too rich. When the IFR is correct, the engine rpm should decrease an equal amount whether you are turning the mixture screw in or out.
quoted from troy patterson
I was about to post this diagnostic but I see Vector has beaten me to it.
Regarding Pusherfan's issue with main circuit tip-in timing; it's actually a really easy, straightforward thing to adjust...but in this case, a picture would probably reduce the necessary amount of text necessary to describe it by a couple hundred words. I'll try to post a photo and explanation from my office computer later today.
