Old 06-27-2010, 07:44 AM
grybrd123 grybrd123 is offline
Cobra Make, Engine: N/A
Hi Woodsy:
The improvements (other than cosmetics of having Shelby’s name on the seats, door handles, brakes etc) that I know about are:
Changed front and rear suspension to accommodate different, deeply dished wheels
Simplified and reduced suspension adjustability
Separated the oil and coolant radiators, placing the oil radiator under the car in a scoop between the front wheels – looks like it reduced ground clearance significantly (I have photos)
Added external door handles
Changed the heater valve actuation to a servo (but kept same crummy valve)
Electric windows
Moved seats inboard an inch or so
Moved steering column inboard to match
Eliminated the rabbit ears and moved the openings further back (probably less noise)
Improved gas tank with a swirl pot (I don’t know if they changed the filler)
They claim an improved frame, but I don’t know what they did
I don’t know what A/C improvements are
In my opinion, the most useful changes are the elimination of the rabbit ears and addition of external door handles, followed by moving the seats inboard and electric windows (assuming they work OK). The oil cooler location looks to me like a REALLY bad idea.
List roller price I was quoted recently by a dealer was $99,900. Initially it was $89,900, but that was raised very shortly after the car appeared.
David
SPC0123
