Old 06-28-2010, 06:28 AM
trularin's Avatar
trularin trularin is offline
Member of the north
Cobra Make, Engine: A Cobra
Undy has a nice list.
What is NOT happening is the freon is being "changed".
If it freezes up, IE ice forms on the compressor parts, that means there is not enough conversion taking place. Does the fan blow in the furnace/air unit?
In a recent set of events for our family, the blower motor was drawing too much current causing the system to shut down the motor. No air across the coils makes the system ice at the compressor because there was not enough conversion taking place.
Insufficient freon should be low on the list of problems...unless something happened to cause the loss.
Electrical - like a motor being shut down - is probably higher in the list.
I do not know how technically inclined you are, but some of these guys can get big money to do a small thing.
I hope this helps!
