Old 06-29-2010, 08:05 AM
Z-linkCobra's Avatar
Z-linkCobra Z-linkCobra is offline
Cobra Make, Engine: Everett Morrison, All aluminum small block ford.
FWB... you need to buy some new needle and seats...lol. We run 8.5 to 9 psi on the race car all day long with no flooding problems.
Fatboy... FWB is right...3/8 o.d. is too small. You need to step it up to 1/2. Pressure is not the biggest factor its volume that you need. With a 750dp your going to run out of fuel with the small line and the restriction of the mechanical pump. Ever taken the line off of a mechanical pump and cranked the motor over...huge pulses in the fuel flow..not a steadt supply. Perfectly ok for cruising and pulling the CObra to the show...but not for going fast.
" If it wont break em loose in 3rd gear, it aint enough power "
