Old 06-29-2010, 08:27 AM
FatBoy's Avatar
FatBoy FatBoy is offline
Cobra Make, Engine: Kirkham #523, 427 S/O
If I by-pass the mechanical fuel pump, can I just disconnect both pipes and join the ends together or do I also need to remove the pump and fit a balnking plate over the hole?
The base of the pump is level with the bottom of the chassis rails, so it is as low as it can go and is below the fuel level in the tank.
Many thanks for your input and the benefit of your experience.
Paul
