Old 06-29-2010, 12:22 PM
FUNFER2's Avatar
FUNFER2 FUNFER2 is offline
Default Show & Tell about your Acusump mounting ect.
I'm thinking about using a Accusump oil system on my new side oiler. I would appreciate your opinions and photo's of your setup.
Mainly used for the Pre-Oliing,...... not for full time road racing.
I have a oil cooler to install.
Canton RR oil pan.
I don't know if I want or need, to use a single or double oil filter "Relocating" kit. I may just buy the sandwich type, for a cleaner install ?
I assume, the best location for the tank is between the front of the engine and the radiator. I'll have to fab-up a mounting bracket. Has anyone mounted one in a different or better location ?
Probably the 3 qt. tank.
12" or the 16" unit.
Electric valve control. (which psi, 35-40/55-60) ?
Check valve.
Gauge.
Regards,
Kevin
