Old 06-29-2010, 04:05 PM
Snakebit's Avatar
Snakebit Snakebit is offline
Club Cobra Member
Cobra Make, Engine: ERA 289 FIA #2100 Rio Red Wimbledon White Stripes 302 stroked to 331 Webers Richmond Road Race 5 speed
Default Best intake gaskets???
I have to replace the intake gaskets on my Weber intake for the third time. First try used Victor Rienz Nitro seal with RTV just on the water ports. Leaked oil into the cylinders. 2nd try Victor Rienz standard gaskets. RTV around water ports and Aviation gasket sealer front and back around the intake ports. One plug is oil fowled on the driver side and notice oil on the exhaust manifold gasket. The other 3 plugs show oil on the end of the threads. The pasenger side is fine.
A few posts recommend Cometic gaskets and using Toyota 00295-00103 sealer. I use The Right Stuff for the front and back seals.
I used 2 studs to line up the gaskets and the manifold when setting it into place. This time I will try 4.
Any coments on the Cometic gaskets and sealer?
Snakebit
