  #166 (permalink)
Old 06-30-2010, 12:25 AM
Zedn's Avatar
Zedn Zedn is offline
Originally Posted by Baz View Post
Liam,
I suppose this thread is of particularly interest to you because of where you are situated with your build. Some say that I was targeted because of this thread. Not so. This thread was started after I had my thorough 5 hour inspection.
Another Cobra owner who has gone before me and has posted on the NSW Cobra Club thread have had their Inspections completed in 2 hours. Mine was 5 hours. It is obvious that changes have been made in the Inspection protocol at the RTA. I will leave you to work out what the motives or objectives of those changes are, but they certainly don't benefit ICV builders. All I am saying, is don't express your feelings or sentiments on this Forum in open threads, only do so by PM's.
In answer to the Brake Test. The answer is a definate NO. The 160kph Brake test is out. Why they want Full ADR 31 Testing again is beyond me and is an issue that my Engineer will be discussing with the RTA hierachy.
Q re Jag Suspension:- In the front suspension, I have done away with the lower Jaguar A Arms as they had limited adjustment capabilities as far as a perfect wheel alignment is concerned. Instead, I installed lower arms from FFR in the USA which are far superior to the original Jag setup and provide for precise and full adjustment. SEE MY GALLERY. I can easily go backwards and fit lower Jaguar A arms, but I know this would be making the car far less safer.
I have fitted Spax Shocks and Eibach springs all round the car, doing away with the Jag setup. This is a far safer and better performing product than the original so I can't see their problem here.
Thanks for your support here Liam, I hope you have picked up a few tips. Don't forget that when you take youe car for Inspection, you don't go with a roof.
Baz
I dont think you were targeted because of this thread, i think there is a lot of paranoia floating around.
I dont plan on fitting a roof at all at this stage, so shouldnt be a problem.
I have also been following a Clubbie on OZclubbies who is about to have an RTA inspection in the next couple of months so will be watching closely. The description of his brake test sounds the same as yours.
In regards to blame of RTA or Engineer that people are talking about, i think its important to just focus the energy on rectifying the problems identified. you have a great looking car and i am sure soon in enough it will be a great looking registered car.
If you need to borrow any standard Jag parts, you are welcome to use my control arms. Also if you want i can measure my front wheel offsets and you can borrow those if they fit.
Good luck with the Operation.
