Old 06-30-2010, 10:00 AM
Flyin_Freddie's Avatar
Flyin_Freddie Flyin_Freddie is offline
Cobra Make, Engine: Superformance #770, Stroked 351W (393 cubes) w/ Tremec TKO-600, 3.27 Torsen locker, 'Hi-Tech' Blue w/ White Stripes, Wilwoods, Bilstein coil overs...and a big ear-to-ear grin!
Default SPF Turn Signal part...
Bxx1....here's a link to a vendor in California who can source the turn signal switch in the steering column...
http://www2.cip1.com/SearchResults.a...+signal+switch
They have two part numbers on the page referenced above...both have dimmer switches in the stalk. Be careful...some of the other part numbers don't appear to have dimmer switches in the stalk. Part number C24-141-953-517-F lists for $149.95 and is an OEM part...it's shown further down the page listed ab
Then they also have a repop unit, part number VWC-141-953-517-F for $49.95. It's the first one listed on the page above.
The turn signal flasher unit is located under the dash...should be a silver metal canister about 1" in diameter, and an inch and a half long, or so. I don't remember if it's a two or three prong unit, but they're both fairly cheap and available at most any auto parts store...Autozone, Kragens, O'Reillys, CarQuest, etc. If you can pull your old one out, it's easy enough to match up in the store...really a no brainer.
FYI...if your turn signals are not blinkin', I'd suspect a bad bulb first, then the blinker itself, and lastly the switch in the column... I've also seen some corrosion in the bulb socket cause problems, as well. IMHO....
Hope this helps, Brother... Holler if you need more help!
BTW...we used to live in Vacaville in the late 50's before Dad was transferred to Japan. Used to take Mom on shopping trips to I Magnum dept store in Sacto...Dad would take us kids to Sam's Hoffbrau for lunch. Good memories...
Flyin_Freddie
"An opinion on everything...an expert at nothin'!"
WARNING: The opinions expressed herein do not necessarily represent those of the management, editors, or owners. We welcome differing opinions, and recognize our responsibility to offer differing views. May cause drowsiness, restlessness, or irritability. Do not operate heavy machinery while using this product. Void in Alaska, Hawaii, and Puerto Rico, or where prohibited, licensed, or regulated by law. We reserve the right to limit quantities. Offer good while supplies last. No substitutions allowed. Please observe posted speed limits. Professional driver on closed course. Do not try this at home. Please wear your seatbelt at all times. Close cover before striking. Use at own risk. Please dispose of properly. Drink responsibly. Prolonged exposure to vapors has been shown to cause cancer in laboratory animals. Do not use this product of you are pregnant, or plan on becoming pregnant. Intentional misuse by deliberately concentrating and inhaling fumes can be dangerous. Always wear safety glasses. In case of eye contact, flush with water and seek immediate medical attention. For occasional use only as directed. Avoid prolonged skin contact. Discontinue use if rash develops. If symptoms persist for more than three days, seek professional medical attention. Hearing protection required beyond this point. Danger: Hot surfaces. Use as directed. Proceed at own risk. Caution: Filling may be hot. Please don't litter. Actual results may vary. It is a violation of Federal Law to use this product in a manner other than as intended. Do not use this product if you have an enlarged prostate, or have difficulty urinating.
