Old 07-02-2010, 08:32 AM
Jerry Clayton's Avatar
Jerry Clayton Jerry Clayton is offline
You can take the flywheel you have and check the balance of it---if it is neutral then its easy to do the replacement
If it is external, add weights to it in 2 places (bolts&washers) til it comes into balance, index those weights to the new wheel, (line up crank bolt pattern) and balance assy, remove the weights and you will be balanced to your engine
If your machinist doesn't understand---find a different balance shop
