Old 07-02-2010, 06:53 PM
patrickt patrickt is offline
Nooooooo...because Chas will not be stupid enough to dignify child games with a reply as poor Ken realized he had done.
Actually he did a very nice job. When I ran the numbers, 8 changes would get you an 89.99% coolant change... but, that ain't 90%, so he is technically correct.
Put brass petcocks in place of the block drain plugs, attach tubing to reach into your drain pan. When changing, drain from the lower rad hose, and both petcocks. You get a complete purge that way and refill through the temp sensor boss on the intake.
Uhhh, I would rather just change a gallon out after eight drives.
