Old 07-05-2010, 04:09 AM
strictlypersonl strictlypersonl is offline
I would check two things:
Is the face of the bellhousing parallel to the block face? You'll have to move the flywheel-mounted dial indicator so that it measures the distance from the flywheel to the mounting face. (Watch out for crankshaft end play!)
As Chas said, is the transmission input shaft too long?
