Old 07-06-2010, 04:38 AM
vector1 vector1 is offline
Cobra Make, Engine: jbl
i think you have a small leak into the coolant somewhere, building pressure which blew the bypass hose and torched the old radiator.
i would do another cooling system pressure check and leave it on a while to see if it is dropping even the least little bit, then i would do a leakdown on all the cylinders with a leakdown gauge.
from there you know you have a good system and can look at other possibilities if nothing comes up.
in addition, if you had a steam pocket leave the engine which is coolant coming in contact with a hot cylinder and enter the radiator it will tear up a radiator pretty quick.
