Old 07-06-2010, 04:11 PM
elmariachi elmariachi is offline
Originally Posted by ekrupa2 View Post
Jim - I am by no means a mechanic, and I only posted as I almost have the same set up us you. I speculate this is a heat issue...rather than a problem with the trans.
Part of it is a heat issue. The vibration/grinding is definitely due to a worn pilot bushing or the pilot shaft pressing against the crank. The hard-to-shift issue may be exacerbated by that as well but I believe heat in the clutch fluid is a primary factor in the clutch fading and not releasing quickly when the pedal is pushed.
