Old 07-07-2010, 05:16 AM
marcalan's Avatar
marcalan marcalan is offline
Cobra Make, Engine: era 289 FIA #2112
I agree, replace the orifice tube and accumulator. I just did this on a "ebay special" I picked up for daily commuting. It was easy. Also, check the O-rings when you disconnect everything and replace those in question. Have Pep Boys or some other shop pull a vacuum on the system after you replace the compressor for 30 minutes to get everything dry (moisture), then recharge as the folks above have stated.
good luck
live for the moment or it may pass you by
