Old 07-08-2010, 08:22 PM
blykins blykins is offline
You may have to drop the trans real quick just to check things out....make sure the flywheel bolts are still tight, pilot bushing looks good, etc. I'd take a look at the input shaft on the trans as well....make sure the bearing doesn't have any slop in it.
If it does it with the clutch out in neutral, then it has to be between the flywheel and the transmission.
Lykins Motorsports, LLC
www.lykinsmotorsports.com
www.customfordcams.com
brent@lykinsmotorsports.com
