Old 07-08-2010, 09:00 PM
Zedn's Avatar
Zedn Zedn is offline
I don't see any form of bump stop.
This system removes the jag bump stops from upper arms. This is a G-force yes? I wonder if there is anything on the lower arm.
I was planning to eventually convert my kit to be the same (mine uses full jag front end). Bump stops are something i hadnt thought of. Also i think if the shock mounted more like it does in the jag (between the upper control arms) it would have less preloading. But that would be a tight fit.
Rebel, i wouldnt be worried about having the same shock, probably more the way its mounted. Thats one of the problems with shocks. It only has to be slightly out of square and puts huge loads on the components.
