Narrowing it down I hope, at least I'm able to find a constant symptom. When I let off the gas, at any RPM and clutch out, I get the light popping (I'm going to go with the experts and swap the header gaskets) put when I ease back into the gas I get the stutter. It just last a second but again, it happens at any RPM immediately after I decelerate then get back into it. Note: If I'm running through the gears hard, no issue, powerful as expected. It just happens when I let off (clutch out) and ease back in (cruising). It's a small hiccup that seems carb related. The Mustang Dyno sowed a fuel ratio of 13-14 from 3500-6000 RPM. Edlebrock idle screws are about 2 turns out (smells rich at idle).
Thanks again!!
Mike
