Old 07-10-2010, 12:46 PM
Ronbo Ronbo is offline
Cobra Make, Engine: Kirkham #570 w Shelby FE
If your buying the car from them I'm sure they can fit one as part of your build.
Any top that is specifically for the original cars should work, although they need a modification for the roll bars at the back and also the top as the Kirkham roll bars are a little taller than an original.
Cobra restorers sells a full kit as well as the side windows, anyone that does canvas / upholstery should be able to do the mods for the roll bars.
You'll need a pattern for the body studs (lift-a-dot posts) as well, but make sure you have the top first to verify location.
Be forwarned that most folks find the top makes the car a real b**ch to get in/out of. So much so that many rarely, if ever, use them.
