Thread: battery issue
Old 07-10-2010, 06:50 PM
BDR879 BDR879 is offline
Cobra Make, Engine: Backdraft 879, Indigo Blue / Wimbledon White, 428 Cobrajet, TKO 500
Originally Posted by charlandk View Post
My fan switch was in the off position also and I always take the battery cut off out to avoid any further battery run down. My volt meter would read at about 14 showing a full charge, but it would either crank over very slow or a couple times not at all.
I am thinking that it was a bad batch of batteries if it is happening to others with similar car #'s.
I have a new battery now but it is raining too much today. I will be going for a long ride tomorrow so after, I should know if the new battery is a fix for the problem.
Took mine out today for a 45 minute sort out run it a bit yesterday also....Fired right up each and every time. I am with you....probably a bad batch of batteries.
Jay, mine was dead from the time we recieved it and had to put an overnight charge on it to get it to go. Not a starter issue according to my engine builder as the new 1200 cranking amp Odyssey looks to be doing the trick.
