Old 07-11-2010, 05:47 PM
stiffy stiffy is offline
Default Garage Update # 21
Guy's,
Its been a while since I have posted any pic's ( been a bit jealous of Aussie's Monster Garage update ).
The painter has been working flat out with 4 coats on the block work and 3 on the plaster, the metal beams needed a few more .
I used the two part apoxy N35 factory floor coating. I started on the right side of the garage as the benches and tools were arriving and they say you should leave it for 7 days before you put heavy stuff on it. I did and it still marked. I think I will wait until it gets a bit warmer and try another coat.
The working side
The display side, this turned up a treat, very happy
The Bar Area taking shape ( thats a 60" TV to give you an idea of area )
Storage and stairs,
R2D2 is hiding in the corner . The problem with buying stuff on the net, you cannot see the size of things, I need to add a room just to store the Vacuum.
Just need to finish the bar area and its party time......
STIFFY
