  #47 (permalink)
Old 07-12-2010, 07:57 AM
Jerry Clayton's Avatar
Jerry Clayton Jerry Clayton is offline
Before you chase the clutch/flywheel further, you should pull the front dampner off the crank to make sure that it hasn't sheared the key and/or turned out of phase with the crank. Also turn the front end of the crank back and forth to try to determine if there is a broken front web between the no 1 main and rod journal--
