Old 07-13-2010, 12:01 PM
Skuzzy Skuzzy is offline
Cobra Make, Engine: LSC427, 427DartSHP
Originally Posted by Bob In Ct View Post
You're both right, you're both wrong.
Using two different filters (one which passes a lot of oil and one which traps very small particles) gives us the best of both worlds - good flow and good filtration.
Since I don't have this setup I'm using a Moroso Racing filter (27 microns) in an effort to get improved flow without the down side of a typical 60 micron racing filter.
Bob
Ok Bob, I am going to poke the fire a bit here.
If the filters are fed in parallel, the filter with the larger micron element would require less oil pressure to push through the filter.
Now the smaller micron filter will require a higher pressure to push the oil through.
Unless there is some type of restrictor or regulator involved, what prevents virtually all the oil from taking the path of least resistance?
I know at some point in time, the larger micron filter will require a higher amount of pressure and then the smaller micron filter would start getting an equal to or higher than percentage of the oil flow.
What am I missing? Or is that the way it is supposed to work?
Sometimes things really do go as planned.
