Old 07-16-2010, 04:10 AM
ha_pe_1968 ha_pe_1968 is offline
Cobra Make, Engine: SPF 2234 Diamond Edition, Roush 427R
Hi!
Just have modified my turn signal and my brake light at the rear to LED. Here in Austria you need amber turn signals. My car has the red rectangular taillights. With the amber LED's you get a perfect amber turn signal light even thru the red taillights. My back running and brake light was not really visible when it was sunny. Bought my LEDs from "www.superbrightleds.com" They have the right sockets 1156 or 1157 and are for 12V. Each lamp have 3 Lumileds 1.5W power LED's with special lenses and they are really a lot brighter then the normal lamps.
One good thing...if you only change the rear turn signal the relay still works.
If you change front and rear then you have to modify the relay. Think one LED is about $23.
Peter
