Old 07-16-2010, 05:21 PM
Ronbo Ronbo is offline
Cobra Make, Engine: Kirkham #570 w Shelby FE
Run two filters, a 40 micron on the pump inlet (to protect the pump). Then place your 8 micron as close as possible to the carb.
The gas tank can shift around slightly, so I'd run AN braided between the pump/filter and tank. The hard line would crack over time.
The tube style AN fittings won't effect flow, the cast ones (low clearance) will.
