  #21 (permalink)
Old 07-17-2010, 11:48 PM
Rare Iron's Avatar
Rare Iron Rare Iron is offline
Originally Posted by undy View Post
I dumped the spirals after suffering massive HP losses. i'm running 3" ID pipes now. They're a bit louder than the spirals but I picked up 50 RWHP. The flow's still crappy though.
Dave, you are really up there in HP correct? The Cobrapacks you are running now are as good as you are going to get as far as flow - with a 4" OD muffler body. As I recall, your HP is enough so that you could be running 4" flowpath mufflers....... This would then require you to have a 4" min. diameter in your merge collector. Hey look at it this way - you gained a lot by going with mine & still some noise control. You could run zoomies through the hood??
