Old 07-18-2010, 05:32 AM
patrickt patrickt is offline
Wish there was a way to test the old voltage regulator so I could be sure, but will not lose sleep over it.............
With your "new" solid state VR you're probably running a system voltage of around 14.6 volts or so. Shut the car off, plug the old VR back in, fire her up and measure the system voltage again. If it's significantly lower (say, 13 volts) then throw it away and look no further.
