Old 07-18-2010, 01:35 PM
SuperHart's Avatar
SuperHart SuperHart is offline
Cobra Make, Engine: Cobra Fibercraft Bodies 427 S/C, 351W disguised as a 427.
Send a message via AIM to SuperHart
Personally, I think you will be happy with the 351W/T-5 combination. With a 3.50 rear ratio at 65 mph I used to rev 2750 RPM in 4th gear with the toploader. The T-5 overdrive lowers it to 1700 RPM at 65 MPH and quiets things down quite a bit. Even with dual quad Holley carbs I can punch it in 5th gear and the car moves out without a bog.
Political correctness is a doctrine, fostered by a delusional, illogical minority, and rabidly promoted by an unscrupulous mainstream media, which holds forth the proposition that it is entirely possible to pick up a turd by the clean end."
