Old 07-20-2010, 07:57 AM
ratdog ratdog is offline
Cobra Make, Engine: Factory Five, 427W
Default I'm about sick of oil leaks
I have a 427W with strike Force heads and it seems to me that the cobra valve covers are just to big,the gasket is out on sides even if I use studs to make sure the gasket is on cover and heads right. I have tried two different type gaskets and still have issues. I have a Canton front sump oil pan and it leaks at rear.I love to clean car and look under hood at a clean engine dept.
But that is not what I have, help guys. about to get aggrevated..
what gaskets have you had luck with?
ff#5501 427w,TKO 600,P/S,Hydroboost,4wheel cobra disc/C Narrowed Mach1 rear, Moser axels,3Link,I Squared
