Old 07-20-2010, 10:28 AM
DANGER DANGER is offline
Cobra Make, Engine: SPO 2644 Roush 427R
On my SPF the upper cross member is pre-drilled from the factory. And the fiberglass wall behind the seat is also pre-cut for belts. All I had to do was remove the rear tires and find the pre-cut slit. I used a razor blade and cut the carpet. Than bolted down the harness and poof done in one hour. This included removing the seats to install the proper hardware for the lap belts....
REMEMBER - You do not want to mount the shoulder harness to the floor... This would cause spinal compression during an accident... The top of the mounting should be no lower than 2" below you shoulders...
Happy Wrenching..
