Old 07-20-2010, 01:24 PM
FIA-ERA FIA-ERA is offline
Cobra Make, Engine: ERA FIA 2008/351W/TOP-LOADER
Yep, I'm right there with you! I have a similar set up and had leaks. I actually use two cork gaskets on each valve cover. I glue one to the head and one to the valve cover. I use studs to hold them together and align it all. I also spray Pam cooking spray on the gaskets before I install, but not to much (don't ask how I know!). It helps when you have to adjust valves. The pan is a tough one till you get it off. Like others have said it could be the pan, the rear seal, or the gasket??? Keep us posted. Thanks, Matt.
