Old 07-20-2010, 03:18 PM
Cobra #3170 Cobra #3170 is offline
Default 30 spline set up
If you are interested in just converting to a locker I have both a Detroit Soft LOCK and a Torsen locker for a Dana 44 with 19 spline stub axles and 3.31 gears. They are both in excellent condition with just test runs on them. I know you are looking to convert to 30 spline but this could be a cheaper alternative. I have 652 LB/Ft of torque and have not twisted a 19 spline stub shaft off yet.
I went back to the stock Salisbury LSD because it worked better than the other lockers I tried.
Originally Posted by Chris L View Post
Hello to everyone;
Can someone please point me in a direction where I may be able to buy some 30 spline drive shafts to suit a Jaguar / Dana 44 IRS to enable a truetrac or similar locker to be fitted to the rear of my Cobra. I have a series 1 Salisbury Jaguar lsd diff and it has a 19 spline set up and a 3;54 ratio. I only wish to change the spline teeth and diameter/bearings if thats possible.
Maybe there is a custom shop that may specialise in a request like this, need some answers in a hurry.......thanks in advance.
Chris L
Australia
