Old 07-20-2010, 04:22 PM
olddog olddog is offline
Originally Posted by undy View Post
The entire portion of the manifold that could leak water into the oil is fully visible. I use a purpose manufactured high viscosity soap suds solution with excellent designed cling characteristics to coat all the potential leaking surface areas. It's just as good as submersion and a heck of a lot less messy. watching a bleed-down test really is not as good as a visual inspection of said areas. The bleed-down method is great when all the areas aren't visible, like an assembled engine's entire cooling system. Initially I'll probably use the bleed-down method when I pressurize the halves of the engine. If it shows results I'll start looking for specifics.
I must have got confused somewhere earlier. Yes soap is a great test. Obviously you know all about leak tests in your line of work. You don't need me to tell you that.
OK it sounds like the intake is totally ruled out, and the intake gaskets maybe not totally but very low probability. I agree the next step is pressure test the block and heads together and go from there.
One question on picture #1. The block deck seems to not be solid where the intake and heads mate up. Is that a drain path to the pan or what?
