Old 07-20-2010, 07:47 PM
olddog olddog is offline
Originally Posted by undy View Post
BTW... today, upon a close visual inspection of the two rear machined flat surfaces of the intake, the surfaces that block off the rear 2 coolant ports of the heads, I could of sworn I saw a bit of porosity on one adjacent to a pushrod hole. hmmm..... I didn't pressure test that end. The impregation will take care of it, assuming it is the leak. The block/heads pressure testing will hopefully show me everything else is tighter than Dick's hatband.
Wish you could have proven that was your leak. It may well be. If the rest of the engine holds pressure, I would bet that was it. If not, you still have to keep looking.
